Speed sensor replacement
Cruise control issue
Hey guys just though id get your feedback on something. I was heading back from work today and i noticed my speedo wasn't working and the abs/ brake light was lit up. I keep reading that it is common and i have to replace the speed sensor on the trans and rear end but i can't seem to find the sensor for the rear end. Any suggestions/ do i even need to change them? 05 5.9 48re trans dana 70 rear. Thanks
VSS is read off the sensor on the rear diff, not transmission. It is commonly called the ABS sensor on the rear diff.
Since I do not see a reply regarding location I will take a guess. On the second gens it is on top of the pumpkin, may be the same for yours.
Dave
Location of the sensor is not in question. Actual naming of the part to find a replacement seems to be the issue.
It is confusing, and he does not even know that he has a AAM axle and stated Dana 70. In 2003 they switched to AAM axles. SnoKng
I thought that the question was the location too. Reading the first post, he states he couldn't find the LOCATION of it. Not what it is called.
" i can't seem to find the sensor for the rear end"
So "for" and not "on" seems to be the issue.
Ha! Ha! on and it is the only 2005 with a dana 70, wonder how it got there in place of the much bigger normal AAM dif? SnoKing
Yea thanks bud it was a special ordered truck direct from mopar... one of one... very rare! It as part of the towing package because the aam diff couldn't handle the payload.
It is this kind of BS when a guy asks a simple question and even the moderator mocks the guy is the reason I didn't renew my membership after 17 years.
Mr. Motorhead, what you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this thread is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
:eek::eek:
:-laf
