The speedometer reading in my '92 auto, 4x4, ext. cab drops out after the auto shifts into overdrive. For example, I can accelerate normally to about 30 mph where the overdrive kicks in. Soon after, the reading will drop back to the 20s range -- and the auto will down shift to 3rd range. Once back in 3rd, then the reading will usually pop up to actual -- and the auto will shift into overdrive again. This irregular cycle can go on and on.
I've replaced the distance sensor and its adapter. I've also replaced the auto's thermo switch.
Comments, Ideas, fixes?
