Spicer u-joint 5188X
bully dog torque managment
Diesel Fuel Additives? What, Why & How Much?
When I did my joints a couple months ago, there was no direct replacement from Spicer.
However, the shop that replaced the ujoints in the rear dshaft used NeapCo joints and simply ground the retaining clips thinner... they were a Spicer equivalent. However close the Spicers are, they wouldn't work as a direct replacement.
steved
One of the replacement u-joints that Mopar sells is a Spicer joint. I will be checking on it tomorrow to see if its the 6-speed or auto joint. The G56 trucks use another u-joint. I'm thinking its the same as the front axle joints.
Marc
When I had the joints replaced in my 04. 5... NO SPICER WOULD CROSS. They were close, but too long across the caps... same goes for the axle joints...
steved
