Aftermarket is available with both grease and non-grease. I learned my lesson on the weaker grease-able with Jeeps.
A FEW???I don’t care who says different, aftermarket joints don’t fit AAM driveline. It’s only a few thousandths too long in the caps or cross but it puts the joints in a bind and causes vibration.
I got it, so he has to go to manual hubs to have 2 low ??. I read somewhere that the front driveshaft on post 2013 do not spin in 2 hi. ??
1/2 way there... other side just needs the lock-out hubs installed. Those are a real PITA.
if its a full time 4x4 system then you need manual hubs to have 2lo. a cad system could have 2lo if you interupt the electric signal to the fork motor
on 2014+ only the axle shafts and spider gears are driven parts in 2hi. the right side inner shaft spins in reverse. something in the tcase engages and gets the gears and shafts up to speed and thus gets the right side inner shaft turning in forward direction so the cad fork can slide the collar over
, Yikes thats a lot of stuff going on
now is the driveline turning in 2 hi on the 2014
, now is the driveline turning in 2 hi on the 2014
