Sport Bike Injectors
Intake Hoses
Guage Questions
I am looking to go to bigger injectors. There used to be a guy named Sport Bike that had some shower heads.
Anybody know how to get a hold of him or any suggestions on bigger injectors. I have BD II's now.
Dennis
Selling the stage II's
Ok Dennis how much do you want for your old stage 2 after you swap em. After riding in your truck I don't know why you think you need to go bigger :D (well ok I guess I know exactly how you feel)
Wes
Depending on what you are looking for, I believe BullyDog is selling some 4s and 5s.
I believe this is SportBike's busy time of the year... and hope he will be back with us this fall. ;)
Not to take away business from John (Sportbike) as I know that he is making some huge showerheads, equal to stage 6 I believe, but the Bully Dog 5's I'm running now are real sweet. I had Sportbikes email addy but somehow lost same, if you can't find it through other sources, let me know and I'll do some searching for you. One word of warning though, these babies will turn the day into night if you really get on it with low boost. Also, Bully Dog recommends fuel line upgrades, i. e. , either drill out or loose entirely your banjo bolts and you better have good fuel pressure before you add them as well, they can really drag it down on WOT runs, even with the Mallory pushing and the Aeroquip fittings. All that being considered, they are still 'streetable' IMHO. I still run with the EZ on the most aggressive setting and can do a somewhat slow start with not much smoke, same as the 3's were but a bit more sensative to the throttle at low boost. Give Bully Dog a call and ask them how much to upgrade from the 2's to whichever you wish, they gave me a $500. 00 credit when I returned the BD 3's. Hope this helps !!!
Scott W.
Thanks for the input. I have called Bully Dog a couple of times and met with less than adequate success. Maybe they just had a couple of bad days.
Wes, how much would they be worth to you. PS hope to see you again this fall in another joint campout.
Big Saint, can you elaborate a little on you experience. Especially in the area of cruise control function, mpg change, and low speed controllabilty, IE towing and backing up.
Dennis
I tried Bully Dog again and got a good response. They must have had an off week.
Thanks KIM
Dennis
Now the final decision, Injectors--starting down a very slipperly slope, clutch, turbo, fuel lines, pusher pump--might as well rob a bank.
Well maybe not !!!
Well maybe not !!!
I know what you mean man. I'm just about to start BOMBing, and already starting to add up costs. Let me know if you need a hinch men to join you on that bank thing!:D
AJB
Enterprise Engine also has big injectors
You can reach SportBike at -- email address removed --
But give Loretta or Doug at Enterprise Engine a call, they also have showerheads for 24 Valve engines.
www.enterpriseengine.com
