I am tired of the lack of headlight on my truck. Has anyone installed the sport lamps in their truck?
jkalchik said:http://www.suvlights.com also has complete harnesses, and also has the nifty little plugs that fit a 9004 socket if you're going make your own wiring harness...
JGK said:Geez, Extreme1, you did good! As I remember, I had to buy one or 2 corner lamps new, but the main housings were used. Maybe $150 tied up in those. About $100 in relays & sockets (3 sets per side) and plugs for the bulbs and to connect to the stock harness, and another $150 more or less in wire, connectors, split loom, fuse block and housing, etc. When I hit the high beams, 3 fillaments are lit. I also have an optional toggle switch to turn on the 4th, unused fillament either in high or low beam.
-Jay
Extreme1 said:... Are you lighting both filiments on the high beam or the low beam? I thought that there might be overheating if that was done.
Extreme1 said:I built one harness for both sides using 2 relays and a diode.
JGK said:When I hit the high beams, 3 filaments are lit. I also have an optional toggle switch to turn on the 4th, unused filament either in high or low beam.
JGK said:I also leave the low beam filament lit in hi mode. Then I have the unsused low filament on a separate toggle switch which I can use in either hi or low mode.
mcdaniel1 said:My question is the 9007 Low that is lit when the high circuit is triggered. How do you accomplish that without a Diode or a 4th relay.
JGK said:... As to the issue of switched hot vs switched ground, I'm not sure which mine is off hand, but if I had to guess, I think my stock harness is the traditional switched hot. In either case, it's not that much of an issue in my case since the stock harness just runs the relay coils...
