Sport Headlight Conversion
Roll top bed covers
guage wiring
Has anyone converted their dual lamp headlights to the sport quad lamp system?I read it can be done for about $350 and was wondering what the results were and where to get the parts.
1998. 5 QC LWB,4:10 LSD,Auto
Emerald Green over driftwood
See TDR Summer 1999 Issue #25, Pg. 50 - and do a search, there have been a couple of pretty good threads on that subject w/in the last month or so.
1999 2500HD 4x4 SLT Driftwood QC LB 3. 55LSD 5spd Camper/Tow, Custom Front Bumper/Brush Guard w/PIAA Pro 90's, PIAA Platinum Headlamp Bulbs, Diamond Plate Bed Caps w/full frt&rr DiaPlate Protectors, Kelly Safari AWR LT255/85-16 tires, 2" Trailmaster lift coming 12/8/99
[This message has been edited by Rob Myers (edited 12-07-1999). ]
I am looking for a source for the headlamp connectors that are used on quad headlamps in the Sport package. No doubt the dealer would sell me a complete wiring harness for $1000, but all I want are the connectors for the inner headlamp. I got the lens/reflectors from the dealer for about $240/pair.
I might try Brite Box tomorrow to see if they can help.
I do not want to buy a complete Brite Box because it is unnecessary IMHO with the Sport lamps.
If you're just looking for the connector and pigtail,I'm sure you can find it at any NAPA parts store. I believe the outer bulbs are 9006's while the inners would be 9005's.
-Mike
99 QC2500 4x4, 5spd, LWB,
LSD, 3. 54, Amethyst, Agate, SLT, Fogs, Camper, Trailer, Slider, Midland CB, 2wd-low,
Smittybilt bars, Y2k alloys, Straight pipe 3", 6-disc Clarion changer, No silencer ring, Sill guards, Tailgate marker lights, and a big chrome foot gas pedal!
Mike Ramos Disciple of BOMB
"RATTLE & HUM"
MikeR is correct, NAPA had the connectors for the extra bulbs that reside in the outer socket of the quad lamp. These are 9007's. The inner pair are the stock 9004's. Today I removed the headlamp assembly from the passenger side of my 97, and discovered that I need four plastic locking rings for the new quad lamps to retain the bulbs. Too late to go to the dealer, naturally. Also I need a relay to drive the extra bulbs. Or maybe I will feed all four bulbs with relays for a little extra brightness.
Tomorrow hopefully I can report success.
The quad lamps are in and working, and I am impressed. The new reflectors put light where you want it. I now have 120W of high beam in each headlamp, like all Sport owners. The low beams are 55W, up from the stock 45W. I installed regular 9004 and 9007 bulbs. I used 16GA wire same as stock, with a NAPA relay to drive the extra high beams.
It cost me about $260 in Dodge parts.
A Sawzall with 24tpi hacksaw blade is the best way to cut the body, and the headlamp carrier on a 97. I believe 98 and up have quad-ready headlamp carriers.
99 and up have quad-ready sheetmetal, so no Sawzall needed.
Some additional info not included in TDR's "Second time Around" in issue 26:
You will need to buy two new bulb retainers, Mopar # 55077046 @ $6. 00 each.
Also two new vents # 04805147 @ $2. 00 each.
On 97 trucks you also have to cut the headlamp carriers to make room for the new reflector asssembly. I wll be doing a 98 truck soon if anyone is interested.
