Okey Doke, I installed my Depo Sport Headlights this morning.
The mechanical part of the installation went very easy. I lowered the bumper about an inch--didn't have to take it all the way off, and I did drill two 3. 5 inch holes with a hole saw through the sheet metal on my '95, and Sawzalled the rest out. Cutting took about 15 minutes! I cleaned up the cuts with a sanding sleeve and it looks very professional and neat.
Right now I only have the turn signals & the 9004's hooked up with the original wiring set-up. (I ran out of time and had to go to work)
I am considering wiring these lights so that only the 9007 Dims are on when the Dims are lit, but both 9004 & 9007 Brights, as well as the 9004 Dims are on when the Brights are on. That way I'll have 6 lights lighting up when on Bright.
But only the 9007 Dims lighting the way when on Dim. Has anybody done this?
I have also thought about wiring it so that ALL 8 lighting elements are on when I switch to Bright and all 4 Dim elements are on when I switch it on Dim. But, I have heard this may overheat the plastic headlight housings.
So my question is has anybody wired their Sports up either of these two ways and had problems? Or has anybody done this and had NO problems?
Or maybe you have wired yours another way?
