2nd Gen Non-Engine/Transmission "Sport" style headlights
Engine/Transmission (1998.5 - 2002) Clutch Disc Question
Engine/Transmission (1998.5 - 2002) Good Mechanic Salem, Or
I will be getting some of the clear headlights like the Ram Sport models have. Mine is a non-sport model and there seem to be a lot of those headlights available now. Does anyone have a recommendation for where to go for these? (the clear, Sport type headlights).
Thanks
Bill
I have to say from what I have seen the off shore brands are not the same quality as the oems. As we watch the world trade balance go nuts I would spend the extra bucks to support America. If you don't want to redo wiring you can still use the factory bulb and socket in the sport light,you will just be short changing your output.
Bob
HCPBILL,
I do not know where LMC gets their parts from but if you wanted to check them out that would be a good question to ask where they come from. I wonder if their sport lights are the same as the factory or knock offs. Bob is right in that if they are bad quality then they might end up turning yellow on you or melting.
Bob
Off shore brands and cheap knock-offs concern me also so, where do you get an OEM Sport Light..... junk yard, dealer or where?. I'd like to do the Sport conversion but am holding off till the quality thing can be found in an off shore/ebay item or just go OEM.
Just using an off shore brand cost around $600 (Very pricey in my mind) if buying a relay conversion harness with it, so what will OEM cost?
I'm not sure where you're getting the $600 number. I did my Sport conversion with Depo brand assemblies from CertiFit Auto Body Parts - Home for around $180 4 years ago, along with another $30 worth of electrical parts to build relay harnesses.
The sport headlights at LMC truck are $300 + $32 shipping = $332 per pair here:
LMC Truck Parts - Page 57
and a sport conversion harness from suvlights.com for $133 + $20 shipping for $153 here:
suvlights.com Dodge Ram (Sport Headlights) Super Heavy Duty Conversion Harness w/4 relays 9004
That comes to $332 + $153= $485 total (not $600... my bad) but still pricey.
So, "2brokrtosmoke" what dealer did you get those sports lights from for $135 each and do you have a PN and year of vehicle you used for ordering? I'd rather get the OEM sport lights if not too pricey.
Dave
I've done this conversion on my '96 3500. It is VERY worthwhile.
I used the SUVlights conversion harness, they took a long time to ship but it's worth the wait. The harness has 4 relays, and lights up both the 9004 & 9007 for high beam, and both for low beam. It's lots of light and not much glare.
A major advantage of the relay'ed harness, is that it takes the current load off your headlight switch. The stock headlight switch is not up to running all 4 bulbs at once, it will self destruct. Ask me how I know.
You have to cut out the inside of your headlight buckets for clearance on the 2nd bulb socket. Use an air operated sawzall to cut like the pictures attached.
You will be very happy with the results!
Thanks to everyone for the advice and suggestions. It is always good to get ideas for the many ways to do this.
Bill
Dave
got them at the local dealer for my 2001, reciept reads as follows:
1 55077042AF HEADLAMP 180. 00 135. 00
1 55077043AF HEADLAMP 180. 00 135. 00
2broke2smoke did you ever put in the headlights that you posted the part#'s for??? Did they fit, etc... ???? I am curious about the part#'s because I came up with a more expensive set of dodge part #'s. 55077025ac and 55077024ac. Thanks, Eric
I just purchased and installed ANZO headlights for my 2001 from Geno's Garage. They were just over 200. Easy to install and still much brighter than stock. My stock headlamps had yellowed and the driver side had a major leak in it. I am running Sylvania SilverStars in place of the bulbs that came with the lights.
So far I am very happy. The road is bright again.
I found this dealer with OEM sport lights (listed as "Headlight Assy") for $176 (right) and $182 (left).
Mopar Parts ~ OEM Dodge, Chrysler, Jeep, Plymouth Parts
Thats $358 plus shipping for the OEM 1999 Sport headlights.
The same site lists the "Lens and Housing" for $96 each. I'm not sure what the difference is between the two prices.
Please select a corresponding number from the illustration below to view the details of that part.
1) Headlamp assy Right 2) Clip Headlamp mounting 3) Headlamp assy Screw
4) Lens and housing Right 5) Park/turn/side Right 6) Mount panel Right
7) Headlamp bulb 8) Headlamp bulb Retainer nut 9) Marker lamp bulb Back
10) Socket Headlamp bulb 11) Marker lamp Marker lamp Back
Dave
I just installed the sport lights in my truck with the suvlight harness, it is much brighter, I did not have to cut anything there was an oval hole behind the stock light already.
I don't know exactly which year Dodge started the Sport Light option. But I think all trucks produced from that point onward have inner fender clearance for the Sport Lights.
Here's a web site that covers the light conversion Dodge Ram Sport Headlight Conversion and possible sources for the parts. There are good aftermarket light units available for much less than the factory part prices.
