I did my conversion to Sport headlights the other day, and are not pleased yet. I want my DRL back! How do I fix it?
To start from the beginning. My truck is a Canadian version with the DRL wich is nice since we have to use daytime drivinglights here in Norway too, but they don't need to come on automatically (but it's easier if they do)
Before I started the conversion I measured what stock power I had at the bulbs, 12,9V is way too low with the engine running (you loose a lot of lights that way) So I made a new harness with three relays and made it switched +12v instead, this together with heavy gauge wiring I now have 14v at my bulbs. And as most others I burn both filaments on the inner lights on high beam. But now doesn't the DRL work as before so it's unplugged at the moment (it's just buzzes the highbeam relays). I have read a lot on the forum and now understand that the DRL module switches the highbeams on and off very fast (in real life the bulbs see this as about 6v) I need something that can trigger my relay for low beams. Is this possible with the stock DRL module? If I choose to ditch the whole DRL module, how do I get my high beam indicator back?
Anybody that have worked around this?
Thanks!
Stig
PS. What a difference in output of light! Still need some small adjustments but it's a lot brighter now.
Thanks!
Stig
