excellent post
If I may give some more input.
I work in gas processing and can tell all that the comments here are right on as far as h2o mist, we use it alot!
1. the mist will dramitically improve your temps
2. If you choose to use h2o mist , do go with distilled to remove impurities as to not cause buildup, if you use regular h2o than you will be stuck with the mist setup from then on or will do alot of chemical cleaning.
OK lets back up a minute, I have for the past year been doing an experiment for a new Ram air set-up and my first move was to installe a temp reading from the air horn to the cab for continuious monitoring and I can tell you that our intercooler is quite efficient, first let me tell you that a 100% effecient air exchanger can at best deliver to you ambient temp plus 20 degrees, thats with 100% efficiency so on a 100 degree day the best temp at the air horn can be 120 degrees, I have proven this theroy to be accurate whithin 2 or 3 degrees. Now with that being said I can also tell you that under a big load and 9 k elevation and 6 to 9 % climbs that our intercooler tends to be a touch undersized or just plain get overloaded, on a 100 degree day I was able to reach airhorn temps of 145 to 150, and a max egt of 1350 degrees, this was with the a/c on as well, I was trying to load up the system to the max.
Let me back up a minute, this was all done with the BHAF in place too. OK then I made an adjustment ( sorry I cant be too in detail about this as this mod may get a patent) . but I can tell you that the mod is a ram air system ... ... ... ... . when I made the mod and under the same pulling conditions I was only able to reach 125 degree at the air horn and 1250 max egt, this was with my comp on 5x5 too and I even lugged the truck down to 1500 rpm and it wouldnt go any higher so I proved its value, mainly what was done was a cooler air was fead to the intercooler, what I am saying from this is that we still have other ways to help before we add h20 mist !
Now let me add one more twist, my mod is not done yet and will get even better, what I am saying is that my ram air is not complete and I was still getting an aproximate 50% of the air from under the hood, I am this week going to get with my fabricator to finish the ram air system and have confidence that I will get even lower combustion air, my goal is ambient air temp plus 20 into the all mighty CUMMINS and I do think that it will be done. Please be patient with me and I WILL keep all of you up to speed with this mod but I just cant yet.
Let me ask you all one... ..... In my mind the intercooler is there for 2 things.
1) to help warm up the air or even out the temps when the ambient is cool or cold ? am I right ?
2) the intercooler is there as a efficience ploy on fuel as well as a means of assisting the motor for complete combustion ? (emmissions) am I right ?
If those 2 things are true than answer me why we cant simply remove the intercooler and then ram air the compressor with cooler air ? what I am saying is that with my new bomb the best I will get is ambient plus 20 ... ... ... . seams to me we could without the intercooler get ambient ????? streighten me out boys... ... ... ... Kevin
