Diesel Freak said:There is definately more than one way to skin a cat. Like I wrote in the other thread, pick a power level and build for it.
Chris, 15 psi off the primary could yeild up to 45 psi off the secondary, but definately not more than that.
Tho, not to burst anyone bubble heres. From the guys I grew up with, the guys make big numbers with singles on 2 liter 4 bangers (900hp, 12,000rpm, blah blah blah). Their big agrument was not PSI totaly, PSI was more for bragging rights. It's was more so CFM... . The more CFM flow to put more air cylinder with less driving pressure the more power you got.
The more CFM on a N/A motor could use the better. This has to be the same with turbo motors.
Velosity is also important, as to how much when you're dealing with boost I'm not sure.
How do you get the biggest straw to push air though? With these stock intake manafolds, is is possible to get enough? I mean Comp and sbentz for example don't use the stockers for a reason right?
If everthing in the intake and exahust piping was increase say . 25" in diamater, same turbos same fueling. The head ported that little bit more to compasate would there be much of a benifit vs. money spent elseware?
