I just ordered a new SPS 62 was wondering if there are any tips or tricks that i should know be for i go to in stall it. Thanks for the help.
TTerry said:I just ordered a new SPS 62 was wondering if there are any tips or tricks that i should know be for i go to in stall it. Thanks for the help.
elandon1201 said:Cut the stock oil return line off about 2 inches from the flange and use High temp hose to run down to the block. It wil save you a TON of Frustration
Cummins724 said:The oil return line that bolts to the bottom of the turbo is hard to get lined up. These turbos require "clocking"... . the compressor housing has 6 bolts that holds it together. You must loosen the 6 bolts & turn the housing until the oil return tube clears it... . then retighten the bolts after you have the housing positioned correctly. I usually take the housing loose & turn it out of my way completely while I hook up the return line. Don't cut the line!
Cummins724 said:I didn't have to bend or crimp my line at all... . just turn the housing & install line..... then set housing & tighten the bolts to spec.
TTerry said:Hay thanks a lot for all the input. Im sure it will help a lot with the install. I was also looking at (latter on down the road) to put in a set of Formula 1 Mach 4 injectors. Would this be a good combo or is there a little better injector out there. Im going to be moving to alaska and i will be towing a trailer a lot when i get up there, this is also my daily driver.
