sqeeks and rattles?
One Pricey 1997 3500 for DC?
ROTORS
I am shopping for a truck. I know I'd like at least a 97 for the better breaking, but what about a quad-cab? Have you gentlemen experienced any sqeeks and rattles with the extra rear doors? I am afraid it may be like a van with barn doors... . thanks, guys!
My y2k quad cab doors are very quiet.
No probs with noise except sometimes if you don't get the rear door closed all the way before you close the front, then you'll hear alot of racket when you go over the bumps. Its not a prob if you make sure to get the rear doors closed completely first.
Also, Ive noticed that the seals around the doors are very good, and w/ all the windows closed, you need to close the final door harder, or the pressure in the truck will keep it from latching all the way. Not a complaint,just an observation.
2k, 17k miles, QC, 4x, 6sp, 3. 54,285/75r16 bfg/at, stock air cleaner (reliable), silencer ring "in" (runs better), popup cmpr, 9000 lbs. 14. 5-16 mpg. VA, DD1's, PS Boost module, DD Elbow... also, Nitrous Oxide piped direct into the block (stealth - to keep the warranty), twin turbos, 10 gallon per minute fuel pump, ECM right out of Don Garlit's Top Fueler (he gave it to me) (for letting him ride in my truck), Super Modified DD1 Injectors ("Hand Honed" with a 1/4" reamer & my 12v Makita). #ad
More BOMBING to come!!
i have owned two chevys, a ford, buick, honda two toyotas, a jeep, and this 2000 dodge 2wd quad cab. this has been the quietest veh to date. except for the engine squelch. but that is discussed in another post. cant go wrong with the quad cab. if you do by used, check the seals around the door, to see if they are damaged. this could cause a rattle if damaged. BTW these a a breeze to replace.
I've had 2 quad cabs... a 99 and now an 01. Never heard a squeak. #ad
01 2500 SLT, LWB, 4x4, 3. 54 Anti Spin... . pretty much stock.
My early '98 quad cab had some minor rattles in the rear doors and it never sounded "right" when shutting the doors. Not really objectionable, though.
My 2001 is much, much better.
'01 ETH/DEE 4x4 QC SLT 3500 4. 10
I had a 99 quad cab and now own a 01 quad cab. I am very very picky about my truck and I have had no complaints with rattles or squeaks due to the extra doors.
2001 3500 QC 6 spd/HO engine leather SLT 60 gal tank Jacobs exhaust brake power everything electric brake controller cobra CB wrap around rear pipe bumber with auxiliary BU lights
bug shield SS step bars
My 98. 5 has had no squeaks, rattles or leaks. 50,000 miles. Would not hesitate to buy another as long as it is a Cummins.
1998. 5;24v,3500,4x4,SLT,QC,5 spd,3. 54LS,4whl. ABS,all options,18k lb. Reese 5th whl. hitch,full length diam. plate running boards,eyebrows & hood dam,bed edges,bedhooks;gray Rhinohide liner,Pac Brake,britebox,"deepdish"mats,matching shell,Sandstone & camel leather,stainless fender eyebrows,exhaust turndown pipe;brush guard,SPA digital boost/egt(pre-turbo) gauge,pillar mount. Lowered rear end 4".
See My Truck
1980,W200 Powerwagon,4 door crewcab,360 gas,747 auto,68k orig. miles,4 coats of Zeebart.
The Powerwagon
My Boat
I travel some very rough roads and at around 18000 miles I developed some small squeaks around the doors nothing bad --cleaning and Silicone spray cleared it right up...
"Have you driven OVER a phord lately"
2001 2500 BRT WHT SPORT QUADCAB 4X4 ETH 3. 54LSD TRLR CMPR PKG ALL OPT XCPT LTHR
Thanks guys! I appreciate all the responses... sounds like DC did a good job with the fit and finish, just lousy material (read: paint).
