Squeeky steering wheel help :)
Found a great deal on a used '97
Auto Transmission "FLUSH" OK?
Hi guys,
Was wondering if any of you folks are experiencing a real squeeky steering wheel? I don't know for sure if it's the wheel squeeking but it's in that general area. Whenever I hit a bump or something, it goes crazy. It also makes heavier noises as I am turning the wheel. Everything seems to be operating fine, just noisy. This started about 2 months ago or so. If anyone has any info, please let me know. Thanks. #ad
Jack
Hi Jack. I've got the same problem on my 99. It's a high pitched squeak, right? It started about a year ago on my truck. When I ease the wheel to the right, it stops. I forgot about the lithium grease solution. I will be trying that tonight. I also noticed that the squeak is more prevalent in warmer weather #ad
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000's on order, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
[This message has been edited by John Berger (edited 05-16-2001). ]
Yes, definately. That is the exact same thing going on with my truck. I am going to try the solutions given here and see how it goes.
Jack
Fixed the noise. Thanks for the tips. I put WD-40 along the steering column under the hood and under the dash. Absolutely no noise whatsoever. Thanks folks!!!
Jack
I tried the lithium grease last night. It did not work, so I doused the whole column from the firewall out with WD-40. It was quiet this morning, but that is not unusual. I'll see how it sounds this afternoon on the way home from work.
Update: The WD-40 worked like a charm. No more squeaking #ad
[This message has been edited by John Berger (edited 05-17-2001). ]
