Scissor jacks are great for providing up and down stability, but don't do much for side to side or front to back stability. Scissor jacks can also provide a little bit of leveling for the trailer.
If I'm thinking of the type of telescoping jack that you are referring to, they provide good up and down and side to side stability because they form a triangle. They don't provide much, if any leveling of the trailer. They only provide a little front to back stability.
I've built a homemade add-on for my scissor jacks - it's a plate that slides under the jack plate and attaches to a piece of 3/4" EMT (conduit) that attaches to the frame about 6' away. As you lower the jack, the plate slides sideways until the jack hits the ground and traps the plate in place; the EMT forms a triangle with the jack and stabilizes the trailer. I've put the one I've made so that it provides front to back stability, I need to make two more and place them side to side, one at the front and one at the rear. If I remember I'll take a picture when I'm camping - that will be in a couple of weeks.
I also use a portable driver to raise/lower my jacks. I still use the manual crank when the going gets tough.
