Engine/Transmission (1998.5 - 2002) Stacking Boxes
I was wondering if it is possible to stack a pm3 with a edge ez and if possible what kind of power it should produce thanks
So does a superchip add timing?? I have a superchip, and i now have a comp as well, can i run both of them togethor, sorry for butting in on the subject...
i'm not sure about the superchip, but the comp adds timing and should not be used with any other timing enchancement.
Tcolesanti said:
I don't know what kind of power it would produce, but yes they will work together.
Tcolesanti i see by your sig you have a kore leveling kit where did you get it and how much did it cost how much lift did it give you thanks
Best thing to do is send Bob Wagner a PM...
He just dynoed with the caTCHER, gained 66 hp. The caTCHER, is basically like an Edge EZ, or a VA box, however the caTCHER puts the power where you really want it. A caTCHER with a nice set of injectors is plenty for most. I have a TST put hardly use it unless I am fooling around! :-laf
What's the CaTCHER?
Dr. Bob said:
Im not familiar with the catcher what kind of horse power is it rated at
Bob, to make a long story short; it's software that gets loaded into the ECM. The horsepower gains are similar to an EZ but the torque curve is a bit fatter which is especially noticeable at the bottom end with quicker throttle response.
So the catcher is better than an edge ez but comparable in horsepower. this all sounds great but where do you get one and how much are they you say you have a tst which one how come you dont use it much can you tow with it and the catcher? thanks
Bob, in this same forum...
Look for... caTCHER ecm (Marco's aka MAD)
:-laf :-laf when you have a few months to read :-laf :-laf
I don't use the TST because the injectors I have with the ECM are more than enough for city and highway driving. I only use the TST when those little ricers, Phords, or Cheby's want to play.
E-mail Bob Wagner or send him a PM.
