Stage 1 vs. Stage 2 AFE
where to put gauges on 3rd gen
Anyone using an AIRAID Air Filter?
Jeep Dude, good to question the ambiguety... That is also a very important part of my job as an airline Captain ;)
I apologize for not making that comment clearer. Sometimes in the runon world of these threads things are taken for granted.
Now, my real world comparison of the Stage 2 with Torque Tube to stage 1 Pro Guard 7 with the Stock air tube. My truck is equipped with a Juice with Attitude, ATS exhaust manifold ( with the ports opened up a little ) and a Edge Ball Bearing Turbo.
My elevation is approximately 2400 ft ASL. The OAT's were in the high 90's. I also have a MBBP muffler (that I love).
Now, under acceleration runs with the Juice set at 1x1. I saw 50 to 100 degrees less peak egt with the STAGE 2 with Torque Tube. Same with steady state cruising as compared to the AFE Stage 1/Pro Guard 7 with stock air hose...
Now, your results most certainly will vary if your truck is not set up identical to mine and you are not running it in Las Vegas! :D
Cheers, Bill
Thanks for the clarification, Bill! Your results seem to be about what I would expect, giving up the TT and going to PG7 with the Stage 1. You've found a compromise that works for you and that's awesome. Personally, I opted for the music (turbo noise) and went with the TT, but compromised some flow for cleaner air with the PG7. Everyone has their own level of compromise... otherwise we'd all just take the filter off!
BTW, Mark, since it wasn't the same filter and no TT you can't use Bill's Stage 1 vs. Stage 2 comparison to make a qualified rebuttal of my original post. I hope you don't tell potential customers "stage 2 is 50-100 degrees cooler than stage 1" based on that post you quoted to me. TT and PG7 might affect 50-100deg, but the intake box itself won't... either one will do a great job, but I just can't see how the Stage 2 is worth the extra dough.
I too am in the market for a new air cleaner.
How does the Pro-Guard 7 in a stage 1 flow compared to stock filter and box, more or less air ? I am assuming that the air is cleaner than with stock filter also.
TIA
Jeff
The PG7 with stage 1 will definitely flow more air than stock. Adding the TT or CBH will get you even more, although the biggest difference with the tube will be the sound. If your truck is stock, you might not see that much of an improvement in EGTs but it should run a tad cooler and maybe spool a tad quicker off the line, although I think people experience that feeling more because of the sound. Might as well just get one and get it out of the way because you'll definitely need it once you add more fuel. You can also go the BHAF route and get just as good of results, however I chose the AFE because I think it looks better under the hood and didn't require me to fight with clearance issues. The scotty system is less $$ and does just as good of a job from what I hear, but I just prefer the more traditional style... to each their own! :)
I was amazed how much faster the turbo spooled up and how much more responsive my truck was with the baffles and the directional fins out of the stock intake. Somehow the turbo lost the silencer ring while I was in there. Just enough noise to hear it but not to loud. It feels real close to what my '01 with comp box and DD2s felt like on level 3. I ordered the MBPP muffler and a AFE replacement air filter which should hopfully be here next week.
"The difference is god awful turbo whine"
Hmmm while I will agree that you can hear the turbo under a load I don't think it is all that loud. Perhaps going up a mountain with a load it might eventually grind on the nerves but I can just barely here mine. I told my wife I was going to see if I could quiet it down and she said to leave it alone... . she likes it :-laf
I left the directional fins in place. They look like they do good by keeping the air uniform as it inters the turbo with that 90degree bend there with the stock tubing. Tho, my truck may lose the silencer deal tonight :)
I wish I kept the directional fins in the elbow. It's suppose to work better with the TAG III. I ripped that peice out with my plyers. But so far I'm using the Stage I along with the TAG III in my Dodge "05". I also replaced the stock intake tube with a 5. 5 inch polished aluminum tube. I didn't notice a differnce in turbo noise. Bringing in the Stage I made a difference though. Pretty soon I'm gonna get the Cool Blue Hose. I want to get the new AFE Torque Tube but the TAG only fits in the CBH so mine as well put it to use. That TAG unit was expensive. I don't think it was worth the price but you do feel a difference.
why not just strap a BHAF straight to the turbo inlet. I'm thinking about doing that with my next filter replacement, would get rid of all that extra plumbing :-laf
Mark, you are correct, I had the Stage 2 system confused with a torque tube. Too be clear, I had the complete stage 2 system that I sold to Nauidvr. Maybe he will post his results soon. .
jBYER I said god awful turbo whine with the stage 2 with my EDGE BALL BEARING TURBO::: Not stock turbo...
Cheers, Bill
Update - AFE Stage 2 installation and EGT drop.
Just arrived back in town Firday night late and the boxes from Billua (AFE Stage 2 intake system) were sitting in my kitchen. Thanks Billua - the system didn't even look used! Installed on Saturday.
Yep - this intake system is much louder than stock (turbo wine and air in rush noise). But I have not had enough time behind the wheel to determine if I like it yet. I have a 5 hour tow coming up on this Saturday, so I am sure that by the time I get done I'll either love it or hate it.
Turbo spools quicker, EGT's are down about 75-100 degrees in same ambient temps as before.
NAUIdvr1
So my question is, is there a noticeable difference going from the stock unit to the stage 1? Is it a $300 difference?
I like the turbo whine or at least I have for the first 5 days I've had the truck :D
Mark Craig,
I noticed that in several of your posts you have mentioned "be sure to get the PG7 filter to keep the dirt out of the engine". It this a problem with the stantard AFE filter?
I have the standard filter with and outwear cover. Is my engine at risk of dirt entering it? You have me a little concerned.
NAUIdvr1
