Stainless Header
Here's pics of the 304 stainless intake!
Tst Cr49
Thought this might get a little chatter going.
Just a little something Hot Rod Diesel has been working on. This is the prototype set, production units will be a direct bolt on kit.
EGT reductions is VERY noticable, and it really does give th truck a completely different sound. You'd really have to hear it to know what I mean.
Here's a short clip of a 70-105 mph run with the TST PM 3 Comp box on level 9. Stock injectors, stock turbo, 3" exhaust that dumps out in front of the rear tire.
http://www.hotroddiesels.info/images/untitled.mpg
3. 5 megs.
Since we're so early in the testing process, it's hard to pinpoint a ballpark retail price. As we get closer to production, we'll have a better idea on the costs. As far as the EGT probe location, we will be moving it around on the manifold to see where we will measure the highest EGT's.
Prototypes for 12 valve and CR 24 valve engines are being built now, and will be available.
wmoody said:
looks awsome but dosent look like there building one for 3rd gen yet :{
If you had clearance and the time/talant to modify the intercooler pipe as well as downpipe, and oil drain it would bolt on to a third gen. Knowing what I know now I would never buy a replacement manifold for a third gen. The second gen's mount easier and put the turbo in a better place IMO.
-Scott
-Scott
well tell us what you know about a replacement manifold! :-laf
Any strength issues? I know somebody else that has been working on one and has had some issues with them cracking over time, even with secondary supports in place. We were supposed to dyno one but haven't gotten around to it just yet.
BTighe said:
could some of that egt loss be from where the probe is mounted?
Or maybe from heat dissipation of the individual runners. Question is. . will the heat loss affect turbo performance in a bad way?
Looks trick though-
Mcarcerano said:
I think to get them to last you may need to build them out of Inconel as it can withstand more heat and still keep its strength.
I'll have to check and see what he made them out of. His truck did seem to have a different sound to it, and it did seem to run better also, just never dyno'ed with it, and since he started having the cracking issues I never tested with one either. His did look almost exactly the same as those pictured above. If somebody ever gets these figured out, it would be a hot seller.
Ted
