I have a comment on the placement of the exhaust temp probe. The temps are going to be hotter the closer the probe is to the exhaust port. You need to know the temps coming off of the exhaust ports to prevent piston damage. The turbo is going to see cooler temps as the turbo is downstream on the exhaust manifold or header. I think this header will allow the turbo to see cooler temp than a cast manifold. From test we have done with diesel engines in farm tractors, you can see about a 300 degree drop from pre-turbo to post-turbo exhaust temps. In short, weather the probe is installed closer to the exhaust port or turbo, there will not be enough of a temp change to save pistons and not the turbo.
