Mcarcerano said:Stainless steel typically has a rather low carbon content, in the range of . 08% to . 15%, and sometimes as low as . 03%. The carbon is needed for hardness, but it also can cause the stainless to become susceptible to corrosion at high temperatures. What happens is this: when chromium-nickel steel is heated to a temperature range of 800° to 1590°F, the carbon in the steel combines with chromium to form chromium carbides. This transformation is called carbide precipitation and reduces the corrosion resistance of the steel. The chromium is reduced in this heat-affected area and makes the steel subject to what is known as intergranular corrosion. Some stainless steels are known as low carbon grades to minimize this carbide precipitation; others, such as 321, are special alloys that reduce carbide precipitation by combining and stabilizing the chromium at elevated temperatures
there are companies that coat headers with a thermal barrier, typically some type of ceramic formula, in order to keep the heat inside the exhaust system. Stainless steel performs this function without the need for add-ons because it has a much lower coefficient of thermal conductivity, thereby keeping more heat inside and transmitting it to the header outlet. Radiated heat is perhaps the most important reason to wrap or ceramic coat the headers to protect the car and the driver from excessive, fatiguing high temperatures.
you could still coat the inside of the header and further improve this.
nickleinonen said:all too have steel crown articulated pistons... they can stand much more heat than our aluminum slugs...
and personally, i'd rather toast a $2000 turbo than a $5000-$8000 engine. much less downtime too with a turbo gone bad than an engine gone bad
Hammer said:Hmmm. .
I have been watching this thread since it started and yet no one has asked how much air the header will flow over the already proven ATS,High Tech and B-D Power exhaust manifolds. See,this header design goes against all known header design and airflow characteristics and I'd be willing to bet once its strapped on a flow bench its design flaws would show easily. To make a header that flows correctly and follows what is known about exhaust air flow,you would have to relocate our turbos. Any header that is designed with bends following bends will never flow properly and create more turbulance inside costing HP and raising egts.
Another thing inquiring minds would like to know here is cost. See while most would just jump on the bandwagon due to it being different,normal owners would like to know what they stand to gain for their money. They would also like to know what they would gain by buying this as compared to the money spent for the proven other manifolds out there. The old theory "bang for your bucks" is what is needed to be known or simply,tell us what we stand to gain for the added price of this show piece or is it simply nothing more than a show piece for the money?... ... ... . Andy
Forrest Nearing said:that's correct, that's why people generally don't build stainless turbo headers or manifolds
