Engine/Transmission (1998.5 - 2002) stalls when cold?
I tried to seach this got a zillion responses so I'll ask now. Since this winter, I start the truck, let it idle a couple mins. , then start to drive. when the throttle goes more than half and/or the doors lock(15ish mph) the truck seems to shut off for 1/2 a second then runs fine the rest of the time. Will repeat only if it sits long enough to get cold again. It has NO other issues and no codes. I've also checked nothing as its 20 degrees outside. I want to make a list to check stuff then I'll heat the garage and look. :rolleyes: Anybody had this? What could it be? I've got a new VP44, good 17psi fuel pressure, no boxes currently on truck. Seems like when the ECM tells the grids to shut off it shuts the whole motor down?
