Red Line's 85 Plus Diesel Fuel Additive Treatment is designed for use in all diesel engines and contains extremely powerful lubricants, detergents, seal conditioners, fuel stabilizers and rust preventatives, but without smoke suppressant. Red Line 85+ contains additional cetane improvers which boost the fuel 5-9 cetane numbers and additional lubricants which reduce wear in low sulfur fuel by 75%. This improvement in lubricity and cetane will reduce detonation, assist starting, help reduce smoking, help prevent fuel system wear and leakage and can provide 5% additional power and efficiency. This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and nonroad engines. Extremely powerful high-temperature detergents clean fuel injectors. Lubricants significantly lengthen injector and pump life and reduce ring friction which is very important for today's low-sulfur fuel. Both Red Line Diesel Fuel Catalyst and 85 Plus are available as a winterized version which will reduce the pour point of a typical fuel by 25°F.
The Red Line Diesel Fuel Catalyst promotes better fuel combustion and fuel system lubrication. Contains powerful high temperature detergents, lubricants and a combustion catalyst. This catalyst reduces smoke dramatically, reduces detonation, and improves fuel economy 4-8% based on fleet and dyno tests. The lubricants can reduce wear in low sulfur fuel by 75%, prolonging injector and fuel pump life. Corrosion inhibitors will help prevent rust and corrosion. - This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and nonroad engines.
Stanadyne Performance Formula Junior Improves Fuel Economy-independent tests have shown up to 8% improvement in MPG.
Easier and Faster Start-up-in cold weather, when fuel can gell or very hot conditions, when fuel viscosity is low.
Reduces Smoke and Particulate Emissions-helps pass smoke-meter tests.
Cleans and Protects Injectors and Other Components-detergents and deposit modifiers help remove varnish and other deposits to prevent plugging.
Reduces Wear or Expensive Fuel Systems-lubricants protect against effects of low sulphur fuel.
Upgrades and Satbilizes Fuel-no need to buy expensive "premium" or blended fuel. Keeps fuel fresher and reduces sludge.
Helps Remove Water-special water demulsifier causes tiny water droplets to come out of suspension/emulsion, so the filter/water separator can be more effective.
Alcohol Free-avoids corrosion and accelerated wear.
Add before filling each tank and store at room temperature.
Cold Weather Protection - reduces #2 diesel fuel pour point by up to 40°F (22°C) and cold filter plug point by up to 25°F (13°C), depending upon base fuel.
Hot Weather Protection - lubricates and cetane improver help when fuel is hot and "thin".
Increases Horsepower - with up to 5 point cetane gain, resulting in better acceleration, power, etc.
Improves Fuel Economy - independent tests have shown up to 8% improvement in MPG.
Easier and Faster Start-Up - in cold weather, when fuel can gel or very hot conditions, when fuel viscosity is low.
Reduces Smoke and Particulate Emissions - helps pass smoke-meter tests.
Cleans and Protects Injectors and Other Components - detergents and deposit modifiers help remove varnish and other deposits to prevent plugging.
Reduces Wear of Expensive Fuel Systems - lubricants protect against effects of low sulphur fuel.
Upgrades and Stabilizes Fuel - no need to buy expensive "premium" or blended fuel. Keeps fuel fresher and reduces sludge.
Helps Remove Water - special water demulsifier causes tiny water droplets to come out of suspension/emulsion, so the filter/water separator can be more effective.
Alcohol Free - avoids corrosion and accelerated wear.
Stanadyne Winter 1000
Fuel Gelling Protection pour point reduced by as much as 40°F (22°C), depending on base fuel gell point
Reduces Filter Waxing: cold filter plug point reduced up to 25°F (13°C), depending on base fuel starting point
Reduces Ice Formulation: water demulsifiers and freeze depressants help keep fuel water free
Cleans and Protects: detergents help remove deposits
Alcohol Free: avoids corrosion and accelerated wear
i know more Bosch rebuilders that sell and standbehind stanodyne or raccor. have never seen redline mentioned or even endorsed by them...
anyways here is all the info that you should have posted with your question/statement. just googled it
