2nd Gen Non-Engine/Transmission Starter contacts
2nd Gen Non-Engine/Transmission service codes for abs light
Does anyone know if the starter contacts in a gasser starter are the same as ours?My dad's 94 half-ton started the clicking thing, and i was wondering if i could fix it with a set of Larry b's starter contacts. :confused:Randy
Different starter [ gear reduction ] , solenoid may be the same , but you do not need the larger contacts because of much less draw.
I called Larry B's but didn't get a chance to talk to Larry to see if they would work. I will probably just replace the starter. My dads truck has about 130k on it ,so it is probably due. Randy
