Starter Problems
bhaf, pumper, bill
fuel filter
Originally posted by Todd T
sorry Chris, i got that. :D
3. connector at shut off solenoid- clean inspect, then jumper the white wire to 12v and verify the solenoid actually pulls up. if not go buy a new one.
One thing that needs clarification is that if you DISCONECT THE PLUG, you have also disconnected the ground for the solenoid. So if you unplug it, and jumper the white (or whatever one it is) wire to 12v+, the solenoid won't do anything. I just wanted to make sure some poor guy doesn't think the solenoid is bad from doing the test wrong. That could be an expensive mistake. If you want to test the pull-up coil, you must put 12v+ to the white wire, and ground the black one at the same time.
Chris
