On my 2002, the starter is staying engaged and powered, even with the key turned off. I came out from a store and started the truck and it sounded like the starter was staying engaged. I turned the key off and the engine shut down but the starter was still engaged and spinning the motor. I turned the key back on and the engine started back up. I turned it off again and the starter kept doing the same thing. I disconnected both negative battery cables and the engine and starter shut down. I tried to reconnect one of the batteries and got a big arc when I touched the cable to the battery. I just put a new lifetime warranty starter from O'Reilly Auto Parts on the truck back in June, so at least that's covered if that's the problem. Any ideas on whether or not it is is the starter or something else? I hope it is the starter since it is lifetime warranty. I appreciate the help.
Lance
Lance
