Good Afternoon,
It has been awhile since I was here last, but I return as a full-fledged TDR member who has a slight and annoying problem that I think somebody out there has the answer to:
I have a 2000 2500 QC 2WD ETC DEE and on 3 occassions the starter stays on after the engine comes to life. At first I thought I was hearing things and it took care of itself within 10-15 seconds. The last 2 times I was sorta in a panic until I got the batteries disconnected and it stopped. When I reconnected one battery it tried to start the again(with key off). I pulled the starter relay, but the same problem when I reconnected one battery. Just as I was about to give up and call a tow truck, I thumped the relay and the starter shut off after the truck started(like it is supposed to). I am inclined to believe that the solenoid(which I believe is built in to the starter) is the cause and the only cure is starter replacement. Is there anyone out there who has had this same problem? If the starter needs to be replaced, is this a Dodge item? or can I obtain one from a Cummins dealer? Any help in this matter is greatly appreciated.
N Dennis
N Dennis
