Starting issue
Tractor Starting Switch
Tractor Battery OR Batteries ?
Dimler
I have a 2006 Ram 2500 with 5.7 Hemi. Several times recently after filling the tank with gasoline, the truck will not start. Cranks fine but does not fire. Wait a couple minutes and it fires up. Have no idea what filling the tank with fuel and non-starting has to do with each other. Anyone have an idea of where to look for the problem?
Sounds like a loose connection somewhere that gets “upset” when you fill the tank. You need a fuel pressure gauge to verify no/little pressure when it doesn’t want to start. Then old school troubleshooting will lead you to the real issue.
That vintage of Chrysler products also had notorious fuel pump relay failure. There is a repair kit to fix it that bypasses the built in relay that is inside the TIPM.
