Howdy everybody.
Just to let you know who I am before I get into my problem.
My name is Joe Lowry and I'm from Loveland CO. (about 1 hr north of Denver)
I have a 1998. 5 Dodge 24 valve 5 speed, 4x4 3/4 ton quad cab. 198,000 miles
Now for the real good stuff.
About 2 months ago I replaced my fuel filter and ever since then I have been having trouble hot starting my truck. It will start fine when it is cool, however when it is wamed up from driving, oh, about 15 minutes it will somtimes not start. When it does not start right away (5 seconds of cranking) I have to just keep cranking on and off for about 5 seconds at a time for sometimes 15 to 20 times before it will start. This is, needless to say, very unhandy for me and hard on the starter. When it does start it is always right away after I start cranking somwhere in the 15 to 20 sequence.
I hope I am making myself clear. Questions if I'm confusing you please.
So here is what I have done,
1st I made sure that there was no air in the line by cracking the banjo bolt on the injector pump and the bumping the starter to make the lift pump run.
I did this about 4 times and bled out alot of fuel but I didn't see any air coming out of it. I don't think that there is any air in the line now. This did not fix the problem.
I should mention that once started it runs as good as it ever did.
2nd I took it to a shop called Diesel Services in Ft. Collins. They could not reproduce the problem when it was there. They said that they checked all the fuel pressures and they were fine. Still had the problem.
3rd On a trip to Neb. It quit in Ogalala. Totally died. It would crank but not start. Took it to a shop up there. The guy thought it was the fuel shutoff valve at first so he checked that out and determined that it was ok. Next after he ran his diagnostics tool he said that the ECM was toast so 3 days and $1600 later I went to pick it up. It started cold so I headed home and went the whole way no problem but when I shut it off at home after a 3 hr drive, it was back to the same old problem. Not Cool.
Next I took it to the dealer and had them check it out. They said it was the injector pump. Now before I spend that kind of money I would like to know if anyone has any idea what it could be and maybe someone else has had this problem.
Any comments, questions, or advice is apperciated
Thank everyone
Joe
Thank everyone
Joe
