Engine/Transmission (1998.5 - 2002) Starting Problem
Engine/Transmission (1998.5 - 2002) Oil Mix Question
2nd Gen Non-Engine/Transmission Adding a grease Zerk fitting ?
Need some help with a problem on my 2002 Ram, cold start is fine but after engine is up to temepture it will not start until it sets and cools off. Tempeture is normal and no other problems noticed.
Do you have any codes? Mine did the same thing on and off for over a year with no codes untill finaly P0216. New VP44 time.
From what I understand the electronics in the pump heat up and the solder fails do to many hot cold cycles
