Need help to identify a hard starting problem. I believe that the injector pump keeps on loosing "prime". It acts like it does after changing the fuel filter. Cranks for a few times and then catches and starts rough before it smooths out. Noticed a small spray of fuel coming from the "return to tank" line, just passed the banjo fitting. (Have a new line on order. )
What I don't understand is first, why is this line under pressure. And second, after putting on a new "check valve", (the line that leaks, connects to a "check valve" at the bottom of the injector pump and runs to a 'T' at the rear of the block) I thought this would prevent the pump from loosing it's prime. That didn't work. I am still loosing prime on the injector pump.
Logically, I have a hard time understanding how counld a return line cause the injector pump to loose it's prime, especally when a check valve is in front of it.
Has anyone else had this problem?
