Engine/Transmission (1994 - 1998) starwheel turning?
2nd Gen Non-Engine/Transmission BD Outlook options?
41jay said:
When your taking off the AFC housing what bit do you use to take off that knok off screw top left screw on the housing if your leaning over the driver side fender weil. I sorta striped out my star wheel allen head how do I fix it? got guages installed this weekend of the 5th in march still haven fun would like to learn about oil coolers for manual transmission so i could put a guage on my brand new rebult NV4500 and see how hot its getten. but for now all yall have fun and don't do any thing I wouldn't dooo :D
The break-off screw is supposed to come out with a torx bit, but mine would not. I had to use a SMALL chissel and SMALL hammer to turn it out. When you have the AFC housing off for the plate install, you can drill through the plug or use an easy-out try to get it out. If it dosn't turn loose, heat the housing (off the pump) to about 250* to 300* but no more, and try it then. Do NOT HEAT THE PLUG DIRECTLY. Aluminum expands more then steel, and so heating may cause it to loosen.
Hope this helps.
