Has anyone put on steel braided brake lines? A friend of mine said I should convert over to steel braided lines and my stopping time would decrease. Does anyone make this kit for the truck or would I have to get them specially ordered?
BHolm said:You guys all keep saying that they expand less than rubber lines. What are you basing that on? The looks? Like I mentioned before the braided lines have rubber inside them. The steel covers are woven and look like they offer a whole lot more stretch than the hard molded stock lines. Stock lines are a whole lot tougher than you guys give them credit for too. When was the last time anyone had a rubber line cut? I off road a lot (not in the Dodge) and have never cut a line. I have run Porsches on the racetrack for years and run stock rubber lines with NO problems at all. They are nothing more than a beauty item.
milehigh. o. said:I have to disagree with this for many reason. I have doing some research on this, since posting the question and have read that the steel line do reduce expansion and preformance. As well with the steel brake lines and with steel water hoses they decrease exansion and can avoid bursting to some degree.
Here are some of the examples I have researched.
1.
Stainless Steel vs. Nylon or Rubber line.
If there is one item you can get that will make an instant, noticeable improvement to your brake feel and performance, switching to a stainless steel braided line is it! When you squeeze your brake lever and force fluid through the hydraulic line to the caliper, the line expands under pressure. This means that a good portion of the effort you put forth from your hand DOESN’T get to the caliper! It makes the line expand. By switching to a stainless steel braided brake line, you restrict the lines expansion characteristics. This means that your hand pressure goes directly to the caliper.
2.
In any braking system there is flex - in the pedal, in the caliper, but most of the flex is in the hose. Every time you step on your brake pedal, up to 1500 pounds of pressure moves brake fluid from the master cylinder to the caliper. Most of the way, the fluid moves through rigid steel lines. Unfortunately, these steel lines can not complete the journey all the way to the caliper because movement in the line is necessary to connect a non-moving part (the chassis) to a moving part (the brake assembly as attached to the wheel). These connecting hoses are made from rubber and nylon. Even with the nylon braiding inside the hose, when that much pressure hits it, it will expand. This expansion, or flex, weakens the braking system as it allows for loss of energy meant for the calipers. In a Stainless Steel Braided Teflon Hose, this flex is reduced dramatically. This means quicker pedal response and shorter braking distances.
3.
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech Stainless Steel brake lines consist of a Teflon® inner line that is covered with a layer of stainless steel woven braid. The Teflon® tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon® and the weave is extremely durable against incidental impact and abrasion. StopTech Stainless Steel brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing.
milehigh. o. said:Well from what I am getting out of this is that I will get a firmer feel out of the pedal, but if I am going to be towing alot and heating up the brakes then I should invest in the lines, but if I am primarily just commuting, its a mood point and it comes down to spending the money.
Am I correct in this assumption?
