Our '96 1/2 T 4x4 started pumping out power steering fluid at the nut that holds the steering arm on to the steering box. I assume that the seal above the arm is bad causing the fluid to run down the shaft to the nut, although I don't understand why it the fluid is not coming out above the steering arm.
How do I replace this seal. Does the box have to be removed from the frame or can the seal be removed after removing the steering arm?
