Steering Box Stabilizer - 2nd gen 4X4
Curt brake controller
1995 dodge 2500
Just installed new PSC Big Bore steering box and can no longer use the stabilizer.
As pictured = all parts included, I "think" I still have instructions but pretty straight forward install.
$100.00 + shipping, money order only.
OK there's got to be someone out there in need of this. What's it going to take to make it yours???
I put a post up a while back offering my 2nd gen brace for free. I couldn't even give it away, I gave it a couple months and then reluctantly threw it out.
I have a plow frame on my truck, not sure if it would work around that? Would have to take alook unless you know off hand.
Other then that I could use it for the original price posted. I could provide a shipping label from FedEx if you had a box and weight, or add to total as posted what ever works for you.
Timd32, sorry I just noticed your reply, need to inscribe to my own thread? Anyhow, look at your underside front end this steering stabilizer connects to the frame with the sway-bar bolts. Installation involves: removal of the nut that secures the pitman arm to the steering box shaft (don’t worry the pitman arm doesn’t need to be removed),unbolting your sway-bar from just the frame (4 bolts), install the (provided) nut/sector shaft extension on the sector shaft, install the stabilizer between the frame and the sway-bar brackets reinstall the 4 bolts.
I don’t think a plow connects to the sway-bar bolts, but not sure? Let me know if you are interested.
Sounds good, yeah I looked at it and think it will clear just fine.
PM an address and I can send a fedex slip for it if you know rough size and weight of a box, does not have to be super exact but close and will mail it out to you with payment.
