The new Mopar box has a completely different feel than the stock or a Borgeson or a Red head. Whether it is a ratio change or valving change or both is hard to tell. It will feel heavier coming from the others. It will also have a lot more road fell and input form the suspension cycling. It should not be tight across center, that would indicate it is adjusted wrong. It still steered easily with a couple fingers going down the road if everything else is good. I put it in with a pump that has 11 years and 260k on it and it will turn the wheels easily both ways sitting still, and that is with wider taller tires than stock…I have done 2 of these and put quite a few miles on them. Once you get used to how it feels and works it is better than the OE. You get much better road feel without the wander on rough roads and an suspension lift, even wit the t-type steering. With a cross over steering system control and feel is much more enhanced.
That describes EXACTLY how my truck feels and drives after installing the larger Mopar pump. I have always wanted to try the "bypass spring pressure/orifice size" mod on the newer pump to see if I could get j easier LOW SPEED turning then it offers out of hte box, but ultimately it drives well enough as is to prevent me from experimenting and possibly ruining the pump…LOL
