Since day one my 2010 has a bad wander problem. When I installed the steering brace it was better. But still constantly correcting the steering wheel. Today I removed the tire rod (inner) to the pitman arm. This was after I had my son move the wheel back and forth. I saw some extra movement in that joint. Once the tie rod was removed I have side to side movement by tugging on the pitman arm. This movement is indepentent of the steering shaft. Is this movement normal? I can see the bearing move also in the steering brace. If this is not normal I'll take a video and take it to the dealer. Thank you for any input.
