Wondering if others have had the steering knuckles on their trucks go bad.
what went wrong on the knuckle???
Yes, both of mine went bad within a month of each other last summer. I have about 80K miles.
Yeah, I'm just wondering if a loose ball joint (Not tighten to spec) could cause enough wear to make useless. And the whole reason I am asking this is I install XRF's uppers and lowers and the left side has play(I torqued everything to specs), enough to want to replace them.
What happened to make them go bad?
Yeah, I'm just wondering if a loose ball joint (Not tighten to spec) could cause enough wear to make useless. And the whole reason I am asking this is I install XRF's uppers and lowers and the left side has play(I torqued everything to specs), enough to want to replace them. I haven't torn it down to check if the knuckle is bad or if the XRF's are shot. They have less than 10k on them.
Can you expand on the problems?
