I put Luke's Links urethane bushings in my 2006 track bar and they are working well. I did the steering linkage upgrade on Monday of this week and added a steering box stabilizer bar. The results are fantastic! I purchased the kit from Moparsupercenter.com - the kit referenced by the OP. I installed the Skyjacker stabilizer and it appears to work much better than the stock unit at 44K miles
The toughest part of the upgrade was getting the old pitman arm off. I ended up cutting it with a Dremel cutoff wheel and spreading it while pulling with a 2-arm Mac Tools puller. The original arm was so close to the box housing that no puller would fit without grinding. It was frustrating. Glad I did it, though.
To maintain my toe-in setting I used two magnetic base lasers stuck to the brake rotors and shined at the wall about 20 ft. away. I made beginning marks on the wall and reset things to those marks as things went together. Things are good.
