I was run off the road the other day by a young lady blasting through a stop sign. She was kind enough to grin and wave as she drove off without stopping.
I was lucky that I missed a railroad signal and utility pole. Unfortunately the railroad left an old bend rail along the side of the road, and it went through the side wall of my right-front tire.
After replacing the tire, the steering wheel was about 30 degrees off to drive straight. I had the front end aligned and the steering wheel is now centered, but the truck (2WD) drives odd. It seems to steer away from center too easily and once in a turn doesn't want to come back straight without more steering force than normal. The problem gets worse as speed increases. Crosswind seems to affect steering more than normal too. Personally, I suspected a camber problem.
I'm going to get a specialty shop to double check the alignment. Several people, including first shop suggest that steering gearbox may have been damaged. If that is the case, can anyone suggest an inexpensive source for a replacement.
Any thoughts or suggestions would be greatly appreciated.
