Steering problems!!!
System box/Bushings?
New Injectors
Steering problems!!! Please Help
I put a 2in body lift on. The steering shaft was short so i lengthened it. . no problems there. But now it goes into the box at a rather steep angle and seems to be binding at certian points in its rotation, i plan on getting a Borgeson shaft, anything else i should do/get?? will this fix it? Help!!
A borgeson should fix it. They use a u-joint that will take more angle over the stock dodge joint. Also their shaft is extendable, from the 2wd box location to a 4wd location with a 3 inch body lift.
Borg shaft should work fine for you. How did you deal with the intercooler piping with the body lift? Reason i ask is because i have a performance accy 2in kit sitting in my garage but the intercooler pipes are what has been stopping me, TIA!
What problems are you having with the piping. I didn't seem to have any issues to put the lift on i had to take out the radiator, so i just pulled the intercooler foward a bit to fit the piping on and the just put it back in its place, everything seems to work fine.
I`m not having a problem, I just looked at it and "assumed" the piping would be a problem. THANKS for the heads up! I think as soon as the winter cold breaks I`ll try and tackle it.
