steering
2wd stinks
Where is Sirius Box on '07
skorski
I have 34k on the 05 and looking to spend some money on an up grade to the steering. I see the borgeson steering shaft advertized in tdr but never hear anyone talk about it. Anyone out there have one and what do you think. Oo.
Specifically what steering problems do you want to address? I thought the Borgeson shaft was just for added strength, and wouldn't offer any steering performance benefit on its own.
Ryan
skorski,
Did you check out your front end as I explained in your thread you started a couple of days ago? What were the results? Give all of us a little feedback so we can help you troubleshoot and solve your problems. Starting a new thread about your same problem is not the way to get different answers. Provide us all with more info.
Help us help you.
I have installed and run Borgensons before. They work fine for a steering shaft. They can cure a sloppy joint problem you may have in an old shaft, but they will not mask worn front end components.
KP
