skorski,
Did you check out your front end as I explained in your thread you started a couple of days ago? What were the results? Give all of us a little feedback so we can help you troubleshoot and solve your problems. Starting a new thread about your same problem is not the way to get different answers. Provide us all with more info.
Help us help you.
I have installed and run Borgensons before. They work fine for a steering shaft. They can cure a sloppy joint problem you may have in an old shaft, but they will not mask worn front end components.
KP
