RSchwarzli
Well, it's done. The NV5600 is in the 1990, and only positive feedback from the truck and myself! I will state the question now that everyone is wondering: Is it worth it? Simply, yes. But I am not sure I would ever want to do another one!
Sorry about the long delay in posting this. As you will see, when I post something I like to do it right. To upload all the pics, type all the steps, copy part numbers and prices etc took 5 hours. But its up now! As long as this does not get lost in forum land maybe we will see some more 5600 conversions!
(mods can we sticky this, post in the instructions section, or???? Thanks!)
Putting a 380 lbs transmission in place of a 175 lbs Getrag is not an easy feat. There is extensive modifications, and a lot of cost associated with it. If you are required to pay someone to do this, I would highly recommend going with a NV 4500 5 speed as It is a mostly bolt in conversion. If you don't mind taking the time, putting out the cost, and have the skills and tools to do it; then the 5600 will be worth your efforts.
For those that don't know, the NV5600 was Dodge's first 6 speed for the Cummins pickups. After the weak 1989-1993 G-360 5 speed Getrags were retired, they were replaced by the NV4500 5 speed trannys. Once 1999 came though, they introduced the NV5600 as the HD 6 speed variant. (Side note: If hunting for a 5600 for your truck, do note that the 1999 transmission had a smaller, weaker input shaft at 1. 125 vs the following years 1. 375” shaft. It is highly recommended you go with the larger shaft for better durability)
So to do this conversion, you will need the basic tools like ratchets, wrenches, impact gun, screw drivers, etc. Some of the other tools that will be helpful are:
- Plasma cutter or sawsall
- Die grinder
- Cutter/Grinder
- Long stroke jack/lifting device for body and engine
- Soldering iron
- 12 point 10 mm socket for starter (need to confirm this size)
- Angleometer
- Metric and Imperial socket sets
- Carbide drill bit set
As for items needed, you will need the following items. Please note I have included cost so that people can be aware of what the cost to do this conversion is.
SUPPLIER COST PART PART NUMBER
1 $4,054. 29 PARTS FROM BLUMENTHALS
NV 5600 4X4 UNIT NV5600
SHIFTER STALK MOPAR 52107612
SHIFT KNOB MOPAR 52104174
KNOB INSERT MOPAR 52108192
DODGE MOUNT (NOT USED IN THE END FROM 4500 I BELIEVE) MOPAR 52019641
RANDOM BLUMENTHAL RUBBER MOUNT (NOT USED)
PIVOT ASSY MOPAR 52087542
CLUTCH FORK MOPAR 52087515
BACKUP SWITCH (NOT USED IN THE END) 14014559
BACKUP SWITCH GASKET 89279
SHIFT LEVER BASE ASSY MOPAR 5086622AA
2 $325. 00 HD CLUTCH HYDRAULICS 2ND GEN
$0. 00 CLUTCH SBC CON FE 13. 375
3 $309. 00 DRIVESHAFT LENGTH CHANGE FRONT AND REAR CUSTOM
4 $35. 31 CLUTCH PIVOT BALL PARTS
SPRING MOPAR 04338855
WASHER MOPAR 06022190
PIVOT MOPAR 52087542
5 $139. 49 transmission OIL 5 GAL PAIL SYNCROMESH OIL-STORE. COM
6 $25 24" 4" STAINLESS PIPE FOR EXHAUST STEEL SUPPLIER
7 $50. 00 RANDOM FASTENERS FROM HARDWARE STORE
10X HEY CAP GR 8 3/8-16 1-3/4' L BELLHOUSING
10X ZIP WASHER 3/8' (7/8 OD X . 141 THICK) BELLHOUSING
2X 5/8 FINE THREAD X 4. 5" LONG GR8 transmission MOUNT
2X 5/8 FINE THREAD LOCK NUTS AND WASHERS transmission MOUNT
8 $113. 00 ENGINE ADAPTER PLATE FROM 1994-2002 LOCAL DIESEL SHOP
9 $175. 00 POLY BUSHINGS ENGINE POLY MOUNTS POLYBUSHING. COM
ENGINE MOUNTS
TRANS/205 MOUNTS
10 $77. 98 CLUTCH TIMKEN THROW OUT BEARNING TIM 614114
11 $316. 40 STARTER FOR 94+ 12V NAPA 4N-6428
12 $224. 02 ACC MATS CARPET DOVE GRAY WITH MASS BACKING 1526-90
13 $33. 88 75/90 SYNTHETIC T CASE OIL
TOTAL $5,878. 37
So with that now covered, let's get into the conversion!
- Die grinder
- Cutter/Grinder
- Soldering iron
- Angleometer
ENGINE MOUNTS
TRANS/205 MOUNTS
TOTAL $5,878. 37
