2nd Gen Non-Engine/Transmission Stereo my '98 Club Cab
2nd Gen Non-Engine/Transmission wondering on the road
2nd Gen Non-Engine/Transmission Sport light conversion done
Vaughn MacKenzie
Over the weekend at the Idaho BOMB party I removed my door panels to replace the outside mirrors and think this would be a good time to start a stereo upgrade (as well as sound deadening). I'm not too versed on car stereo equipment. Looking over Crutchfield it says my factory speakers have a built in amp at each speaker, therefore when I install aftermarket speakers I must buy an amp to replace the built-in ones that'll be coming out.
Not wanting to spend a fortune I want to get something like this kit
Kenwood KFC-P508 P Series 5-1/4" component speaker system at Crutchfield.com
but really don't have much clue what to get for an amp. I definitely want more power & performance than stock but nothing like a megawatt killer system :-laf I'm thinking 200-300w should suffice?
If I have the speakers in the doors, in the back, and the tweeters, I need a 3 channel amp? Do the A-pillar tweeters need an amp. . . I'm thinking probably not so a 2-channel should work.
For now I'm OK with the stock head unit but that'll get replaced later on down the road. Mine didn't originally come with Infiniti but I did install the tweeter A-pillars, so I want to make it like an Infiniti system.
Lastly I understand removing the interior rear seat panels on a Club Cab is a PITA, is this true? Fortunately on a '98 you don't have to deal with the seat belts since they're in the seat. When I get ready to do the back seat the whole interior will come out for sound deadening while I'm at it.
Vaughn
If you have the Infinity sound system then you have a complicated system. On each front door speaker is a 2 channel amp -- one for the front speaker and column tweeter and one for the rear speaker. There's a pile of wires too: power, 2 input channels from the head unit (radio) and 2 output channels to the tweeter and rear speaker.
If it's not an Infinity system then it's just speakers in the door and a simple upgrade. All the power is from the head unit.
Luckily it did not come with infinity. . . I just went out and pulled a door speaker to be sure and there's no amp on it, just a speaker. So I will just order a good set of speakers plus a couple tweeters and I should be good to go for now. Later on will get an amp and aftermarket head unit. Thanks Road Dog.
I left the factory connector in place and used spade crimps to make a little adapter cable. 'cause one day you might want to restore the original speakers.
If you order from crutchfield they should send you an adapter, My mind is shot I redid mine last fall and I think they included something I dont remember cutting anything
