Steve St. Ladder Bars Installed
Track Bar Replaced -- Results!
Incorrect EGT Probe Install
All I can say is WHEW! I'm glad that's over.
The install went fine on my '99 QC SB 4x4. Thanks to Steve for being by the phone to make sure that we got the answers we needed to install these without too many problems.
As far as how to do the install, it's pretty straightforward. But you must be meticulous with measurements and fit up. My advice is to fit up everything with clamps first then tack weld the tabs onto the axle. Then fit everything up again and finish with the front mount. Then adjust and you're done. Should be simple. But that's not how it goes.
These are the rear tab welds after they are done. When we got them they were the same size. So a little creative modification to the tabs was needed. My understanding is that this is needed with all the kits. I chose to grind 3/16th" off the one tab to set the bolt level with the axle. You can also accomplish the same by lifting the outboard tab and filling in the void with weld. We also were unable to set the tabs at 90 degrees to the floor due to spce restrictions. We were able to set the tabs at 90 degrees to the axle thought which turned out to be ~80 to the floor. This seemed acceptable to us. A word of advice, use a small tip welder. We had a really hard time getting welds down in between those tabs due to the space resticions. Don't worry too much about warping the axle tubes. We would weld a little and stop. When we would check the tube, it was warm but not hot. The tabs would get hot, but the tube was fine. I don't mean pour the coals to it, but if you're careful you shouldn't have any problems with welding on the axle tubes. You can also see the proximity to other components there. Tack the tabs in place WITH THE HARDWARE ON. Then slide the bolt out as far as you can and remove as much hardware as you can. Steve told me to set the angle of the bars at 9 degrees. When I talked to the gentleman who designed the things he said you should match the angle of the driveshaft. When I did this it was 8. 5 degrees. This tells me that the number angle is not so important as it is to match the angle of the bars to the angle of the driveshaft when the truck is unloaded and level. I took these measurements about 20 times to make sure everything is kosher. I don't think I varied by more than 1/2 degree. It is really tricky.
This is the front mount. On a SB QC you will find that you can put the mount no where else than between the front spring mount and the body mount. Steve has ground them to fit, but more griding may be needed. The passenger side was easier than the driver side because you can reach behind the frame rail. The driver side has the fuel tank RIGHT behind the frame. So when drilling the frame I recommend sliding a piece of metal tubing around the drill bit so that only 1/2" of the bit sticks out. That way when the bit goes through it doesn't hit the tank or the fuel lines on the other side. That would suck. Just the driver's side took me almost 2 hrs to mount. :eek:
Once they are mounted, you will have to cut the front bolt on the spring pack. If you don't, when you hit a good size bump, you will bend the bars. And that would suck too.
Here's what they look like when they are done. Don't forget to install Steve's safety straps. I don't really think you'd need them but... You need to adjust them so that they are under slight tension to no tension. Then lock them down. No problemo.
From the outside, this is what they look like. And as far as performance goes, they do everything Steve says they do. It gives a little stiffer ride, but not harsh. It actually takes some of the harshness out of the ride. And seem to give a more sure feel to the truck as it drives.
My final comments. If you are going to do this yourself, be prepared for some frustration. It's not really the kit, it's fitting it to the truck that's hard. If possible take the truck to a shop and have it done. That's the easiest. But make sure they know what they are doing. They can really screw things up if they aren't careful. If anyone has any questions, let me know. I will be on vacation for the 4th (I need it after this) and won't answer until after I get back, but I will answer your questions. Hope this helps you guys make an informed decision on adding ladder bars to your trucks. Thanks again Steve!
I forgot to add that my payment to the fellow who helped me with my truck is that I have to help him wire the below car. Do you think that will be payment enough? I think that would be less work and more fun. Don't you agree?:D
Sorry to hear you had so much trouble. I had mine installed by a monster truck builder that Steve put me in touch with.
I couldn't be happier with mine. The ride is unchanged. Power goes right to the ground with zero axle hop or wind up.
Wait until winter time or some poor traction surface, then you will apprieciate the bars.
Thanks for the feedback Amianthus. I have taken notes from his install and am adding them to the install instructions (very detailed already - a little over 2 pages long). I put a letter in with the first 12 sets of bars with my phone number on it in case of any questions and I'm taking notes on those calls and adding more information to the install instructions where necessary. If anyone has purchased a set of bars already and wants the updated instructions just email me at -- email address removed -- .
Correct me if I'm wrong but the hardest parts for you were welding the tabs on the axle and mounting the forward plate on the driver's side. There is more room on the long bed trucks on the forward mount and between the frame rail and tank which makes that easier than on that SB trucks. On the welding of the tabs to the axle it is definately a tough job, that's why from the very beginning I've said anyone purchasing these needs to go to an EXPERIENCED fabrication shop to have the tabs welded on - and I've always put emphasis on that (it will take an estimated 2. 5-3 hrs labor at the welding shop). The tabs can be mounted straight on the axle rather than slightly crooked as yours are. There are 4 sets of bars installed out there, 2 by the original shop, and 2 by Enterprise - and they all are on there straight, but it is tight to get them mounted. The plates can be welded on with all the hardware in place, it will be easier to do the welding if you just use the welder to fill in the space between the outside tab and the axle rather than grinding material off of the inside one - because you will have more space inside the tabs in order to work. There is about a 1/4 inch gap between the axle and outside tabs that needs to be filled. All of the sets installed by Enterprise and the original shop have been done this way. If you need to remove the hardware later (such as to replace a heim joint for example) then you would simply have to loosen the brake line at the backing plate in order to be able to slide the bolt out (and then bleed the brakes after reinstalling it).
I'm glad they are working great for you and again thanks for the feedback.
-Steve St. Laurent
Supplier of SS Ladder Bars
I should clarify that there were no problems with the install per se. It was just a tough install. That's all. If you are going to do it, be aware that on the SB QC it's not easy.
As far as the tabs being crooked, we set them that way on purpose. It helps to keep the heim centered on the "pin". That way if the axle articulates for some reason, the heim will be less apt to bind one way or the other. If it were straight, the heim would be at an angle and thus limiting it's rotational movement. Grant you it's probably negligable, but we thought it couldn't hurt. That and if we'd set them square, we wouldn't be able to adjust the lock nut. It woulda bound up against the tabs.
If anyone wants any other input drop me a line. I'll be more than happy to give my insight into the install.
Excellent article Amianthus! That must have takin 2 hours to do. :D
What Chassis/Car is your friends engine in? NICE!
It's a '62 Plymouth Savoy. And it took me 9 hrs for the install. It took me the same amount of time for my clutch. With the same guy helping me. Maybe I should find a new partner to help me. :D Can't wait to get started on the plymouth though. Should be fun!!!
I'll make sure to print out this thread when I get a chance to do my install. . no rest for the weary. . had them in the garage for a week and slobbered on them at least daily. .
Steve. . e-mail a revised set of install instructions please...
I might take them to sacramento to Alston's shop. . [he is a top notch race car frame fabricator. . if ya don't know his name]
