I've found that shifting my 03 Dodge (6-speed, high output) in cold weather gets rather stiff. Does anyone else have this problem?
I'm wondering if I can use synthetic fluid in the transmission (NV 5600). The owner's manual says the transmission fluid does not require periodic changing, but if you do need to add/change the fluid to use Mopar manual transmission fluid (PN 4874464). (A local dealer said this is petroleum-based. )
If I can find a synthetic-based fluid, will Chrysler have objections to me using it?
Thanks.
GL
Thanks.
GL
