Stock boost pressure???
93 Dually need flat surface mt rims HELP
Front springs
Hi Guys,
I got my Autometer boost and pyrometer installed this weekend and have a couple of questions. I am able to get 13 lbs. of boost and 1050*F EGT under full throttle with a small load (<2,000 lbs). I am going to try a larger load tomorrow. Are these numbers correct for a 21 cm turbo? I have a 16 cm hotend, but have not been able to install it yet. Please see my signature for the current modifications. Thanks for the input.
Jeremy Sweeten 1992 Dodge W-250 4x4 Cummins Diesel, Intercooled,LE Package, 168K, 518 AT, Warner Hubs, Dana 60HD 4,060 lb. front axle and Dana 70 6,084 lb. limited slip rear axle with 3. 54 gears, NPG 205 transfer case, 3. 5" Banks exhaust straight pipe, K&N air filter. Tekonsha Voyager XP electric brake controller. Una-Goose 30,000 lb. gooseneck hitch.
http://home.earthlink.net/~sweeten1/index.htm
Hello Jeremy!
My 1992 D250 has engine CPL1351 and your CPL should be the same. My Cummins manual shows that this CPL should have 31 to 39 in. Hg boost, which is 15. 23 to 19. 16 PSI. Your boost sounds a little low, but it will probably be higher with a larger load on it.
I have collected all the parts to fabricate a complete 4" exhaust with a 5" outlet, along with Power Wagon injectors, and a 16cm housing. With these modifications and a little pump tweaking, I hope to be at around 30 PSI boost.
Piers recently commented on a boost question from Bushwakr by saying that a first generation with 16 cm housing should have 21-22 PSI at not over 1100 degrees EGT. He recommended adjusting the fueling to get 24 PSI boost. This was only a day or so ago.
Good Luck in your quest for more power!
92 D250 Auto Trans-Currently stock except for TCI special torque convertor. Now adding 16cm turbo housing, complete 4" exhaust, tachometer, pyrometer, and transmission temperature gauge. Injectors in the near future.
Also have 1984 Volvo D260 with inline 6 diesel made by Volkswagen.
