Hey Steve, I responded to this message on the DTR, however I though cross-posting to the TDR would be of some use to members who do not frequent both sites.
We have no dyno charts for you, and indeed we question the wisdom of anyone who dynos an air system on the 2nd Gen RAMs. There are no sensors in the air stream that influence the maps or fueling in any way, so in order to gain any HP, you'd need to be seriously starving the turbo of air, making it work so hard to pump air that it heats up the air that it is pumping. Added to this, is the fact that any air system, whether it be an open filter or a closed system needs fresh air flow to work properly, and you'll find that your dyno results will be seriously skewed.
On the EGT reduction side, we've gathered numbers from customers over the past 1. 5 years, as well as our own testing. In every case, and every air system, unloaded cruise EGT reductions are minimal. As weight, extent of modifications, and throttle opening went up, EGT reductions increased.
Our results are as follows:
BHAF - Reports of anywhere between a 25F increase to 50F decrease in EGTs. Our own testing showed a 0F decrease in EGTs while at unloaded cruise, 50F at loaded cruise, and 50F at WOT. A heat shield gave another 25F reduction at loaded and WOT.
Oiled filter (type of filter doesn't seem to matter) - 0F - 50F cruise EGT reductions, up to 125F reductions at loaded cruise (weights were anywhere between 8K and 15K reported) and WOT conditions. Heat shields seemed to help a little more, with additional reductions of up to 50F.
Volant air system - Only 3 results found on this system, each showing a max EGT reduction of 200F at WOT, on fairly heavily modified trucks (HX40 class turbos, DD 3 and SM injectors, Edge Comp boxes). No reports on cruise EGT reductions, and attempts to contact the customers reporting the numbers were unsuccessful.
Scotty Air II - This is going to seem like a bit of an informercial now, however since we distribute the system, we've done alot more testing with it, and gathered many more results.
Unload cruise conditions - 50F average reduction at cruise. Numbers anywhere between 0F and 100F on trucks anywhere between stock, and relatively heavily modified (HX40, B1 class turbos, DD 3's to Mach 6 injectors, Edge DRAG Comps, TST PM3 Comps).
Loaded cruise reductions (weights between 6K and 38K) in Hush mode - 85F average reduction. Numbers between 0F and 150F on trucks between stock power levels and fairly heavily modified.
Loaded cruise reductions (same weight range) in dual inlet mode - 160F average, numbers between 50F and 250F.
WOT conditions, unloaded truck, Hush mode - 120F average. Numbers between 50F and 250F (two results, each eliminated due to error concerns, as other closest results were 200F).
WOT conditions, unloaded truck, dual inet - 220F average. Numbers between 100F and 350F (1 400F reduction run eliminated due to error concerns).
WOT conditions, loaded truck, hush mode - no numbers
WOT conditions, loaded truck, dual inlet - Only 1 result here, and this was on my own '01 Dodge, with a DRAG Comp, RV275 injectors, stock HX35 turbo. I did this before Scott and I entered into our partnership on the systems. Load weight was 15K, trailer weight 3500 lbs. Testing done in direct drive showed 1450F on the pyro with stock airbox, and throttle held open until 80 MPH. With the air system, 1150F max EGTs. In OD, pyrometer was pegged by 50 MPH, and remained pegged until 80 MPH. With the II installed, max EGTs went to 1250F and stayed until throttle was back down at 80 MPH.
In the last 4 months, we haven't had alot of new numbers gathered. To be honest, we haven't seen a need, as the reductions are real, and repeated on a variety of trucks, under a variety of circumstances. The latest test truck is an 02 that we are testing a B1B on. Fueling box is a TST PM3 Comp and injectors are DD2s. No numbers read at cruise, just WOT conditions. Stock airbox gave us a solid planting of the 1500F pyrometer. Scotty in hush mode showed a slower rise to 1500F, needle bouncing slightly on the peg. Dual inlet mode has given us max EGTs of 1300F.
For other results, a glance through the TDR and DTR archives should get you other numbers. Dee Rawson also did an excellent test measuring EGTs and IATs of the BHAF versus the Scotty II during towing, and up a grade.
