Stock Cp3 Limit??
Getting water pump free from engine?
anyone check rear preload with 175,000+ miles. Wondering what value u got??
I was wondering if turning up the rail pressure on my smarty would cause my cp3 to fail earlier? Also about how much hp can one expect to squeeze outta the little guy?? Thanks in advance!
Yes & No. . Factory CP3s are good to 550-600hp dial In, builds are good form 650-725hp, Now all kinds of variables need to be factor in, I have Never been able to confirm any precise rule, but for sure any certainty Duals are the ticket for competition & race, With some of the tuning available singles just cannot keep up, Now stay under 650Hp no problem with proper tuning and support.
Injectors are probably in more danger from higher RP than the CP-3 in normal usage scenarios. If you are playing with RP you need a gauge to make sure it doesn't go to high for extended periods.
Preciate it guys!! Never thought about harming the injectors from rail pressure. Guess I'll turn it down a notch or two!!! TC would you say 750 is pretty much the limit for ANY single out there? I have been considering the dragon fire cp3 from industrial injection. Don't have the $$$ for duals!! Don't want to start an opinion war either so I'm just asking you from your personal experience of course!
Well All the flow rates are within xxxML form all of us, All of us make Tweak Pumps but it comes at a high cost and longevity is severely shorten. Right now we are offering dual Kits with Pump at low cost that many are taking advantage of. John form floor makes the highest flow CP3, all the modded pumps have seen My test Bench so I now what they flow. With some of the tuning thats Now available No single is going to keep up with xx Mil-sec Duration. Don't even think about competing will duals at competition levels.
